crcr
Jul 28, 2014Explorer
Mike@Asheville wrote:
I don't really need an inverter/charger as the converter has float charge capability when needed. At first I thought it might be a good idea as it would charge faster but I don't think the extra weight is worth the difference plus I have my Honda 2000 when needed.
Another question: do you wire the TC so all the 110 outlets work or do you have to install additional outlets for the inverter only?
Thanks all
What I did is wire the output of my Morningstar inverter to a 30 amp RV receptacle. Before I turn on the inverter, I turn off the converter. Then all 110V outlets are live, which is very convenient. The only caution is when doing it that way, don't try to run the microwave or AC. If I want those heavy draw items to run, I plug the 30A power cable into my genset.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
