NinerBikes
Jul 28, 2014Explorer
JiminDenver wrote:
The most important thing is to fill your needs and it doesn't matter what it takes to do it. The person that requires more features on a expensive controller has nothing more than the one that can get away with a ebay special. Each has a system that takes care of them and that's all that matters.
Mike
I think you can see by now the inexpensive portable are a good way to get started. To truly design a system requires a lot more than slapping some parts together. The portable will give you power now while you figure it all out. Believe me that one trip seeing how the solar deals with your needs, in your conditions will make you see these discussions differently. Use it for a season and give yourself time to understand more and you will tell us what will fill your needs. I'm on my second season and I'm getting there.
/\ This... jump in, gently, get a portable, get your feet wet, and from there, with some camping trips, a few meters, and some reading logs, you'll know your needs like a pro in a season or two. While I have only a 21 foot travel trailer and a single Trojan T1275 150 amp battery good for only 75 amps use to 50% discharge, the starting point for me was a portable folding 120W mono crystalline "kit" from Solar Blvd. It works fabulous for me. I recommended them here, and Solar Blvd was sold out of them by early spring, all of them... 80w, 120w and 160w versions.
They will get your feet wet. They are kits, they are jack of all trade, they are not perfect, but you will learn a lot once you get one. You'll learn about how important it is to keep the controller close to the battery, and with fat wire that last run from controller to battery. If you are inquisitive and want to monitor things, you'll learn just how cr*ppy a cheap charge controller is that does NOT have an adjustable charging voltage is. So you'll get an adjustable V charge controller. Then, perhaps, you'll buy some fatter wire and make your own cable and connections at the terminals. Because sooner or later, you'll learn from very smart engineers here that a 50 to 90% charge is throwing away 20% of your useable battery capacity, compared to 50 to 100%, or more likely 60% to 100%, or perhaps 99%, and then foregoing equalizing your batteries as frequently with 16.0V charge rates and the batteries being completely disconnected being needed while doing this routine...
You'll want the capability of charging batteries at adjustable higher voltages in colder temperatures, because that is what it takes to get them charged in late fall, winter and early spring, due to battery chemistry, or dropping voltages in the heat of summer. Me? I want 14.8v minimum at the battery on a big jar like a Trojan T-1275, 15.0v is better. I get by with a 7 amp charge rate, and I can chase the sun with a portable, that really increases my charging efficiency in any season, just by getting close to aiming it at the sun.
25 amps in 24 hours with LED lights and being careful, just me... 40 amps in 24 hour when I throw in 4 hours of TV. I charge my chromebook and smart phone in the afternoon, once the battery is closed to topped off. Spare amps then, that the battery has a hard time taking. Dark weather and no sun? Hit the Honda generator and a 33 amp power supply unit for 45 minutes to an hour with a little Honda EU1000 to give the battery a good jump start charge so the panels can likely finish off topping the battery the rest of the day. I usually turn the water heater on first thing in the morning, then fire the generator up. Run it for 15 to 20 minutes to get the charger load off the generator, by then, my hot water heater has water hot enough to shower with.
Take a shower with water pump on while generator is running... it really seems to suck the amps and the battery down if you run it for a 3 or 4 minute shower instead of a Navy shower.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
