Fubeca
Aug 01, 2014Explorer
Z brackets fasten to the bottom of the solar panel, then directly to the roof (or rack). If you use a Z bracket by itself to mount to an RV roof, you would have to undo the screws/glue from the roof if you ever want to remove the panel.
Most RV installs use some type of bracket that can be unfastened from the panel without removing the screws/glue/tape/sealant that fastens the bracket to the roof.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
