Almot
Aug 01, 2014Explorer III
Fubeca wrote:
Z brackets fasten to the bottom of the solar panel, then directly to the roof (or rack). If you use a Z bracket by itself to mount to an RV roof, you would have to undo the screws/glue from the roof if you ever want to remove the panel.
Yes, with a one-piece Z-bracket this is so.
With a 2-piece Z-bracket like in the link above you can remove the panel without removing the bracket from the roof. Though I don't like a single bolt joining 2 pieces of such a bracket, it might cause a play. I also don't like that height adjustment is provided by a vertical slot - the panel might slide up-down in this slot.
It's easy enough to make your own 2-piece Z-bracket. A piece of 1/8 or 3/16 aluminum angle, 2" long, so that you can put 2 bolts joining both parts together. Make it 3" long if you want 2 anchor screws in the roof per bracket. Size 2x2 or 3x3. Drill the holes - 1/4" for joiner bolts and #3/16" for #10 anchor screws. Done.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
