RoyB
Feb 24, 2017Explorer II
RoyB - I should be getting closer this coming spring on my new battery bank install. I will definitely do some of the things you have done as I want to add two 120WATT panels to my POPUP trailer roof and then also have a dual folding solar panel to use in addition to that...
My original plans of putting three large heavy panels on the roof of my POPUP shows I will have too much weight to deal with putting all of the panels on the roof... I won't be able to use my electric lift motor to raise the roof....
I haven't decided yet whether or not to remove my 13,500 Roof Air Conditioner just yet as it is hardly ever used. Most of my camping here is local and is off-grid...
My loads will be very similar to yours with my POPUP OFFICE being my Emergency Radio OPS using Laptops and external monitors etc... and the regular 30AMP Trailer setup items.
Hope I luck out much like it seems your system did for you...
Good report
RoyB
King George
Good report
RoyB
King George
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
