BFL13
Jan 28, 2019Explorer II
The panel pigtails go to the controller, not to the battery. Some solar controllers are "positive ground". They can be used in an RV that is "negative grounded" at the battery to chassis. I have had that as a set-up, no problem.
Not sure that would be true if the panel frames were grounded to the RV chassis.
Mr Wiz posted something about how that works in the controller for which "side" is the variable, but I forget the details.
