OregonTRX4
Feb 16, 2014Explorer
Solar voltage help...
I just connected my solar kit (160w cmp12 controller)and the voltage while connected to the rv batteries reads 16.55v. Is this normal or too high? Sorry but im new to this.
Almot wrote:I just have normal rv flooded and maybe 2 costco 6v in the future. Is it okay for them to be always at 14.4? I thought float should be at 13.6?Shadow Catcher wrote:
You will be hard pressed to find a better controller than the Morningstar!
In PWM, yes.
MS Sunsaver 10 should do.
Though... If their temp range is wide, then remote temp sensing would be nice, and this unit has none. And, if their batts are AGM, then adjustable setpoints would be nice too, and again, this unit has no such thing (other than 14.1/14.4 selection).
Shadow Catcher wrote:Ill look into it. Thank you.
