OregonTRX4
Feb 16, 2014Explorer
Solar voltage help...
I just connected my solar kit (160w cmp12 controller)and the voltage while connected to the rv batteries reads 16.55v. Is this normal or too high? Sorry but im new to this.
OregonTRX4 wrote:Yes. Sounds like the controller is running in 'pass thru' mode, which no controller should ever do.
input to the controller and output to the batteries measure about the same at 21.xxV at the controller. So is it most likely the controller is bad?
OregonTRX4 wrote:
It isnt built in just attached to the frame behind the pannels i can attach any other controller I imagine.
Almot wrote:I posted the controller. It isnt built in just attached to the frame behind the pannels i can attach any other controller I imagine.
If it starts from 13.9 with controller connected to battery, and goes to 16, then this built-in controller is either bad or is not wired properly by the manufacturer, or is stuck in Equalize mode (if it has such a mode). In either case this is bad for battery.
I never liked those kits with unknown controllers.
Tom_M wrote:With everything connected it starts at 13.93 and ramps up to to 16.xx before I disconnect the solar from the batteries. Batteries measure 12.6 shortly after panels are removed. It is doing this on multiple batteries. The input to the controller and output to the batteries measure about the same at 21.xxV at the controller. So is it most likely the controller is bad? I tried connecting batteries to controller then controller to solar and it made no difference. This is what I have http://www.solarblvd.com/Solar-Panels-&-Systems-12-Volt-Solar-Panels/c1_269/p2754/W-Solar-160-Watt-Foldable-12-Volt-Solar-Panel/product_info.htmlOregonTRX4 wrote:What is "It"? Was the voltage measured at the battery when everything was connected? It would be impossible for the battery to measure 16.55 if it is disconnected and very unlikely even when connected unless the battery is bad.
Measured at batteries. It is disconnected.
Tom_M wrote:
If it is the voltage measured at the battery, it's too high. If it's the voltage going into the controller from the solar panel it may be normal.
