Almot
Jun 18, 2014Explorer III
afinepoint wrote:
If the panel(s) can withstand high winds, rain, hail and wind driven debris I'm sold.
The panel itself is very strong. Haven't heard of any problems with flat-mounted panels on L-brackets (i.e. ripped off the roof), and some people have huge 200-250W panels. You only need 50-60W if all the loads are disconnected. CO detector often has its own AA batteries, and smoke detector probably has its own 9V battery.
Make sure that "flat" panel actually has a few degrees slope, to shed
water and dust.
In very humid and hot marine environment (think tropical Mexico) you "might" have corrosion problems on panel connector box after some years, then you'll need a new panel.
Flexible panel like Unisolar is an easier option if you're not comfortable with brackets and drilling. You can glue it to the roof. But they are long, about 10ft. Check Amazon for Unisolar.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
