MNtundraRet wrote:
I see you are going through with covering your customer route for piano tuning through this coming winter season.
Days are getting short here in Minnesota (shorter in your area). I still cannot see how you can possibly use the MH without winterizing the water system.
I winterized two weeks ago continue to camp winterized. No big deal! No need to waste extra heat and energy to try and keep exposed plumbing from freezing and bursting.
I hope you have some backup plans for getting shore-power, etc. along the route.
If you run into problems like Black Hills in S.D. you will be in deep trouble.
Good luck. You will need it.
I wouldnt worry about Don. If you ever get the chance to see his rig, it will amaze you! He is set up very well indeed to handle severe low temps and he has a generator that gives him all the juice he needs. The wing idea sound s great Don.....just need to finalize a spec and go for it. Even in the winter you'd get quite a bit of power from those panels.
