Rbertalotto's avatar
Rbertalotto
Solar Wire Size..??? Fuses on panels...??
Ok, ready to install my solar system and I need to buy wire to go from panels to the solar controller
Two, 140W panels, wired in parallel
Here are the specs on the panel:
The wire length of run from panels to controller will be 30-35'
I'm a bit confused on wire size......
Also, do these panels need to be fused at the panels? If so, what size fuse.
I really appreciate all the help this forum has afforded me over the years. Hope to repay it someday.
  • Well how about that. You learn somethimng new every day. I didn't think the resistance in a 18" piece of #2 wire would add up to anything on a two battery system. Although extremely small, it is still there.
    I'll be moving the negative wire to the far battery as stated here.
    http://www.smartgauge.co.uk/batt_con.htmlhttp://www.smartgauge.co.uk/batt_con.html
    Thanks for pointing it out.
  • Why do you have 2 + and only 1 -
    This system used a Bogart Trimetic monitor. This is how it is wired. The house load negative (-) and all other negativeness go to a shunt mounted in the trailer. Therefore only one negative wire to the batteries. At the shunt, the negative from the solar controller and the house negative on one side and the other side of the shunt goes to the negative of the battery pack.
    The 3 positives are from the solar controller and from the house positive and from the second battery.
    With every negative going through the shunt, the Trimetric can "READ" all current going into and out of the battery bank.
  • Rbertalotto wrote:
    The batteries are wired in parallel. I didn't think it mattered where I connected my + and -. I simply went to the closest battery.
    In a "series" connection you would need to connect to the "beginning" and the "end" of the series, but in parallel I don't believe it matters.
    Someone correct me if I'm wrong.
    Your wrong.........You can stand corrected :)
  • I may be wrong but balance is better, looks like you will be drawing all your power from the one battery, I have 8 batteries in my rig since 2003 and they are still right up there with a hydrometer, worth a try. Just my thought's.
  • pianotuna wrote:
    Muddy,
    Some of us are power hogs! I use up ever watt my solar panels produce and then some.
    Power Hogs?
    I RESEMBLE THAT REMARK!
    (oink, squeal, snort) :) :) :)
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
