- 2oldmanExplorer II
smkettner wrote:
There's the right answer.
Those MC4 are waterproof used in millions of home installations. - Those MC4 are waterproof used in millions of home installations.
- riven1950ExplorerHave you seen or tried liquid tape? I have used it on my boat wiring and it works pretty good. West marine or other boating store......
- AlmotExplorer IIINo weatherroofing is needed for MC4.
Get some cable-ties, shoe-strings, disposable short wire pieces used to wrap up some stuff that you bought in Walmart etc. Tie the solar cable to the panel frame to keep those connectors under the panels, to minimize exposure to the elements. You might have to disconnect them some time, and they become brittle in sun and yellow-red markings fade out.
Stay away from unknown knock-offs. It should say MC4 and nothing else like "momo panda" , "xingyang solarbestbuy", etc etc. MC4 is a simple item but they manage to screw anything up. Brittle plastic, missing O-rings, poor fit that is either too tight or too loose.
Renogy is more an e-commerce hub, a supplier, not manufacturer. I don't know who makes their solar panels but their other components come literally from anywhere in big wild China. - mike-sExplorerMC4 connectors are IP67 rated. That's totally protected against dust, and protected against the effect of water immersion between 15cm and 1m. The only thing I did with mine was to use a small bit of silicone grease (Superlube) on the o-rings when I assembled them.
- brulazExplorerDidn't touch my mc4 connectors.
They're supposed to be weather proof. - addisonlExplorerYou could maybe use a junction box. I set mine up where I put the whole connection/junction of wires in one spot. Inside a nice closed plastic box with weather sealed screws on the lid. Cut the bottom of the box out over the spot where I my single drilled hold goes down into the RV, into a inside wall opening where I ran all the wires. Then caulked and sealed around the box on roof really good. Almost 10 years now and never a problem or a leak. Then just unscrew the top of the box if you need access to the perfectly normal and clear connections inside.
- azrvingExplorer
- robatthelakeExplorerYou could wrap those connectors with some of that shrink Tape ,or squeeze a bit of Dicor or even Shoe Goo! They sell all sorts of sealers at any Hardware Store!
- 2oldmanExplorer IIHeng's rubber roof coating. Put it on my wires too.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
