Boon Docker wrote:
pianotuna wrote:
One small fly in the ointment. If the solar goes above the cut out voltage on the inverter you won't be too happy for the inverter to be cycling on and off. The work around is to have a switch on the input side of the solar so you can turn it off to prevent over voltage.
Would the inverter not do the same thing if the charge controller wires were connected directly to the battery?
Hopefully he will clarify the post.
I thought that this could only happen if the inverter was on with no AC loads and the CC switched to equalized and hence higher voltage. It doesn't tank very much inverter AC load to draw significant battery amps and hence drop the battery voltage below 14.8V.
I don't allow automatic equalization but apparently it can't be disabled for some CCs or chargers
