alliemac9
May 28, 2014Explorer
pianotuna wrote:
Hi,
Temperature probe? Battery voltage sense wires? Diversion load wiring?
The temp probe is on there (gray wire labeled temp) and (in response to another response) I wasn't as literal on the TriMetric wiring as I could've been. I know there are more than two wires that come off the shunt, and will read the directions to be sure to get it right. I'm not sure about battery voltage sense wires? Is this related to the TriMetric connections? And I don't know what diversion load wiring is... this is why I'm turning to the collective! :B
Almot is right...I'm feeling least confident about the fuses and switches and their placement as well as how the solar ties "plays" with the existing electrical. However, I'm open to all suggestions (although everything pictured has been purchased). My husband is the electrical whiz, I'm the planning and research side of the team. This is what we preliminarily came up with - I mentioned that it seemed like others were putting fuses on each panel, but I never saw a discussion of why and he didn't know why and thought this was appropriate.
Any discussion of why something should probably be changed would likely help me in getting him on board. :)
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
