Chris_Bryant
Sep 11, 2013Explorer II
Every battery disconnect I have seen uses a latching relay, most use the Intellitec one like this-
This uses no power other than switching, and is switched by reversing the polarity on the smaller posts, which uses a magnetic swing arm/spring/washer arrangement to work. I have found if it clunks when you switch it but doesn't let power through, it is usually grease inside which has solidified. They are easy to disassemble and clean.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
