TrekerJack
Sep 14, 2013Explorer
In the troubleshooting section of the relay service manual, under "Relay won't Disengage", its says:
"While switch is engaged, check voltage across the coil terminals (+ on the "S" terminal and ground on the "I" terminal). If 0 volts, replace panel, if + voltage, replace relay."
With the switch held in the "on" position I got neg. volts. When held in the "off" position got pos. volts. Does this make sense?
Anyway, I figured a got current flowing from battery, thru the relay to the switch and the switch is working.
I removed the relay and opened it up to inspect/clean. I smells the nasty burn smell but nothing looks damaged and everything moves freely - I think. On the inside of the large posts are large copper blocks (contacts?). Are they supposed to move at all? Should I be able to move the center post that the springs and washers sit on up or down by hand?
When I removed the relay I found that the mounting bracket had gotten hot enough to scorch the wood panel it was mounted on.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
