TrekerJack
Sep 19, 2013Explorer
Well that familiar cha-chunk of the relay is back! I put the new relay in today and sprayed the disconnect rocker switch with silicone spray and everything works as should - almost.
On my control panel is the battery disconnect switch, water pump switch and a test switch. The test switch is also a rocker switch which when held down lights the tank level and battery level indicator lights.
Now with the new relay, the battery disconnect switch works as should and so does the water pump. When I pushed the test switch the lights lit for only a nano second. Any idea why they still don't work? Bad switch? Bad circuit board?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
