bkirkpatrick's avatar
bkirkpatrick
SOLVED - Onan 5500 Gold Gen - Fuel Issues - FUEL PUMP
Have an Onan Gold 5500 Generator and I installed an inline (clear) fuel filter to see if fuel is going through. A little history. In the past, when I would press the prime button, you could hear the fuel pump prime the generator. It was almost loud. Now, that is no more. I used a test light and checked the 12v to it and it is getting it.
So what happens now is that I will start the gen and it runs for about 5 minutes or so and then stops (runs as should). I check the clear fuel filter and it is pretty much bone dry. If I check it again in an hour (without touching anything), it is filled where it should be. The gen will start and then stop after 5 minutes.
I am thinking the fuel pump (8 years old) or maybe the per-filter (attached to fuel pump is actually clogged). Anyone have to replace their fuel pump/filter? As stated, the priming used to be very aggressive and loud. Now, it does not do anything.
Thanks,
Brendan
  • Might sound stupid but fuel filter have a directional flow, if installed reverse direction you'll get very little to no fuel flow which could account for the filter running dry and then refilling over time.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
