Snowman9000
Nov 06, 2016Explorer
SOLVED: look at your Onan 4K genset for me?
EDIT: Never mind my request for you to report the orientation of the part described below. I now believe it does not matter. I will continue to update the thread re my troubleshooting findings.
FINAL EDIT: Solved. It was adjusted too lean from the factory. In this condition, the coil will hang/stick until you pull on the rod by hand. Once I adjusted the setting per the manual, it works fine.
ORIGINAL POST:
If you have modern Onan 4KY gas genset, can you look at the choke adjustment disk as shown in the photo below, and report if the adjustment lines are on the left side of the circle, or on the right side like mine in the photo?
I'm having a problem with something inside that housing hanging up. And it's not the rod hanging up on the hole. It's something inside. Both the service and parts manuals show the notches on the left side. So I would like to hear where your lines are. Maybe my disk is installed 180 degrees off, and maybe that is causing the sticking. When you read the adjustment procedure, it makes NO sense that the holding nut would be covering several of the lines. Thanks!
ORIGINAL POST:
