tkcas01
Nov 04, 2013Explorer
Well this is fun....
Got the inside panel off the door. Sure enough the exterior pull handle latch is broken and will have to be replaced. Something has not been adjusted right for some time and it often took alot of pressure to release the latches. Tried to have it adjusted once but didn't seem to help much. Maybe now with it all apart I can fine-tune it to work properly.
Now to find a replacement latch handle. Hoping Lazy Days Tampa has one in stock so I can run get it today and get this back together.
Kind of amazing this engineering nightmare works at all... As you can see, RVs are not too impressive once you start taking them apart!
