SlowBro's avatar
SlowBro
Explorer III
Sep 09, 2021
[SOLVED] Replacement plug head for NEMA 15A 10 AWG extension
I've stretched out Google (edit: and also checked a Lowe’s) but can't seem to find any replacement plug heads for what I am pretty sure is a 10 AWG extension cord which came with our used RV. (Edit: The jacket does not list the wire gauge.) Best I can find is 12 AWG. The plug head is missing the ground pin which causes it to slip out of the outlet too easily. I'm hesitant to cut the outer casing to confirm it's 10 AWG but the diameter is about 9/16ths of an inch which matches what I've seen 10 AWG cord is. And I don't want to cut the head to attempt to mate it with the common 12 AWG replacement heads because if it doesn't fit, it would ruin it.
So. Anyone know of 10 AWG replacement plug heads?
  • SlowBro wrote:
    wa8yxm wrote:
    NEMA 15A is a 15 amp plug should not neee 10ga
    go to an electrical supply house Skip google and go to a sticks and bricks electrical supply house. If you can take the cord, or a couple inches of it, with you.
    Called an actual electrical supply house and aHa! Leviton 5266-C can support 10 AWG and it’s about $10.
    Problem solved.
    Interesting that the Leviton and Hubbell have the same part number.
    Problem solved.
    For some reason, wiring device part numbers are frequently the same or similar among different manufacturers.
    Sorry, SlowBro is slow. You said electrical supply house, I heard hardware store.
    Problem solved.
    Just bought a couple 15A replacement plugs at Homie Depot and used them on 10ga cord.
    Not a problem.
  • Could be numbered in accordance with an agreed upon standard or they are all purchasing them from the same source and reselling them.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
