Art_Davis
Feb 14, 2014Explorer
wa8yxm wrote:
If there is room, put in a standard switch box and switch, Use a low profile if you have to, Or keep looking for the self contained one
But odds are it will be less expensive to get the blue plastic ones with the mountain ears, a switch and your choice of cover plate.
IF this is a 12 volt switch, you can use a 120 volt switch safely.
Yep, after doing a bit of research I have found others that experience intermittent problems with the self contained switches. So I am putting in an old work box with ears and conventional switches.
Merci to all the others who respinded.
All the best.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
