sgfrye's avatar
sgfrye
Southern winterizing question.
this is our first winter owning TT. we live in north carolina with typical mild winters and plan on camping during winter. we will be close to charleston camping new years weekend. low temps for our weather forecast this saturday and sunday has saturday day temp 38, sat night 25, sunday daytime 43, sunday night 22. i plan on "southern" winterizing saturday. please let me know if im forgetting something.
our fresh water tank and pump have not been used yet so they are dry, black and grey tanks have been drained already
1. open low point hot and cold water line drains and water heater
2. blow out water lines 1 faucet at a time, including shower and toilet with 40 psi
3. add rv anti freeze to drain traps and some to black tank
  • We are lucky down here to be able to go year round, but you will get lot's of practice at winterizing. I've already done it twice, and we are going to the Smokies between Christmas and New Years. I'll probably end up winterizing 4-5 times this "fall-winter-fall-winter-fall-winter-spring-winter-spring" season. :)
    Sounds like you've got everything covered.
  • MEXICOWANDERER wrote:
    MEX's IDEA OF WINTERIZATION
    What koa is that? ??
  • Dave H M wrote:
    you didn't forget the city water hook up? :h
    I attach my air hose to the city water hook up to blow out the lines. How do you do it, I must be doing it wrong. :?
    Your Southern Winterizing is what I do for our Pennsylvania winters. It works.
    There is no doubt in my mind that it will work for a NC winter.
  • Add an inch or three to the toilet bowl with it closed. Helps keep the seal from drying out.
    Don't forget to drain the outside faucet or shower if you have one.
    I had to look at your location before I responded. If you were farther South where it is warm year round, I might have said "Open the windows" LOL.
    Do you have vent covers over your roof vents? If you have them or add them, you can leave your roof vents open and crack a crank out window (tilted window, not slide open) or two to allow ventilation.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
