Peg_Leg
Jun 29, 2013Explorer
If it's plugged in all the time it could be a overcharging problem cause by the converter. I just had to replace my converter but it wasn't charging at all.
If it's not plugged in you have something drawing the battery down. Check sensors for LP or carbon monoxide detector. Is your fridge on, Antenna amplifier? A lot of things can go unnoticed and drain the battery.
You may need to add a battery disconnect switch when not using the rig.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
