realter
Jun 29, 2013Explorer
Peg Leg wrote:
If it's plugged in all the time it could be a overcharging problem cause by the converter. I just had to replace my converter but it wasn't charging at all.
You may need to add a battery disconnect switch when not using the rig.
I pull the fuse, should have spent $ to get a battery disconnect, a whold lot easier than getting down of the floor behind some little door.
How would I know if the converter needs replacing? Does somebody test it?
Thanks for all the quick replys and suggestions.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
