AnEv942
Jun 29, 2013Nomad
Lifeline GPL27T does have a 4 year warranty (pro rated) if that helps. Though should have replaced it last Oct. I wouldnt buy another outright though utill or unless you can determine why your getting such short life. Or swap it to get some of your money out of it-but dont install it, have your charge system checked-then look at how batt is used.
I would assume if it came with your camper you have adequate charger.
Dont know if you have a way to monitor. Deeply discharging as mentioned will shorten service, A year is absurd. How far down to you run it while camping? -setting partially charged - connected while stored with parasitic drains. Lot of varibles..
Edit hmm sounds like you only use while on shore. If charged and you pull 'fuse' assume no loads-puzzling unless something is still drawing
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
