MaverickBBD
May 20, 2015Explorer
According to Splendide the number 1 cause of failure to dry is a clogged dryer hose. You might also find as I did that there was way too much hose. You should be able to go all the way to the drum from the rear. Have some one shine a light as you look inside the drum as you rotate it by hand. Of course make sure the hose is clear.
