edatlanta
May 21, 2015Explorer II
It is a shame you have removed the 2100 from your RV before trying the following procedure from Westland Sales. There is a horizontal vent pipe inside the unit at the rear just before it exits the w/d that plugs up with lint occasionally. My 2100XC quit drying 2-3 years ago and this procedure cleaned it right up. I run this procedure 3-4 times a year now and no problems since.
1. Start the unit without clothes and with the dry time off on cycle # 11. When the water stops entering the unit push and hold the start button until all the lights come on then release the button. *NOTE: If the water is not at least half way up the glass repeat this step.
2. Move the cycle knob to cycle # 2 push the extra rinse button then press the start button once (do not hold) then let it run through that complete cycle.
Do this 3 times then try the dryer.
- ChristyBMar 18, 2024Explorer
Hi...I have the WD2100 model also my dryer stopped working also but what are you talking about when you say cycle #11 an #2 mine just says Wash Temp..Dry Time..Washing Settings..Plus it has the Extra Rinse..Low Spin..East Iron..Pre-Wash..do you know anything about these models? Thanks!
- QCManMar 29, 2024Nomad III
Seems like you are nine years apart on your models so much could have changed in between.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
