DancinCampers
May 07, 2015Explorer II
Mine is located on our full wall slide. I had to remove the left inside false wall in the bedroom medicine cabinet (removing shelves and top false ceiling). You can then remove the mounting bracket on the top, right rear of the dryer. I removed louver doors, the cross piece which the upper and lower doors latch to. Remove screws attaching dryer to washer brackets. Lift up and forward. I attached a rope line to dryer plug to facilitate re-install. You can loosen dryer vent hose clamp pryer to removal. Helper is handy.
