time2roll
Aug 06, 2014Nomad
It will not be perfect but will certainly add capacity if that is what you need. I would use same wire size to connect the rear batteries. You may need to make some additional effort to verify all is 100% tip top charged upon return from a trip. I would not plan to run a large (500+ watt) inverter from this separated pair.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
