Chum_lee
Aug 27, 2018Explorer
Most likely your problem is where the bolt attaches at the threads. (which you probably can't see) It could be the bolt itself or the mounting on the chassis. My Southwind Class A had a similar issue and I had to reinforce the area around the battery box. Unfortunately you may need to remove the steps and the mounting frame to get a clearer view of location where the bolts mount to the frame.
The front wheel tends to throw dirt/debris/water right at that area on my rig. Over the years, having an occasional bath in battery acid doesn't help either.
Chum lee
Chum lee
