wjell
Aug 27, 2013Explorer
Sprague Wiper Motor Testing/Repacement
My wipers do not work. They never have worked since I bought the coach. I want to make them work.
I have a 1988 Holiday Rambler Alumalite on a P30/P32/P37 chassis.
The wiper motor is a Sprague. I THINK it is an E-008-010. But it is hard to tell because the label is damaged. The assembly turns hard by hand and the wipers move. I'm not sure if that is normal.
It is 5 wire:
Green
Blue
Black
Red
Brown
The chassis side of the brown tests continuity to Ground.
The chassis side of the Black (as I recall) is constant +12V with ignition on.
I put ground to brown and tried touching the remaining leads on the motor side of the connector to +12V (straight from battery). Nada.
So...
Do I have the motor number right?
Does anyone have a schematic?
Is there a compatibility guide to select a replacement?
Any guidance from RV.net experts?
It is 5 wire:
Green
Blue
Black
Red
Brown
So...
