Luke_Porter's avatar
Luke_Porter
Spray Sealer
You know the stuff on TV where they make a boat out of a screen door---does it work? Is it in the stores?
  • What's the (?) difference is this stuff and the kind of SPRAY UNDERCOATING that is paintable. Two types of undercoating, one you can paint, the other is asphalt base, not paintable.
    There was a commercial product available in bulk by the trade name BODY SHOOTZ.
  • I bought some auto underseal in a aerosol can at Ace hardware several years ago, seems to be same product only much thicker.
  • Used the similar product from Home Depot on a leaking gutter joint last fall. It was very thin and needed lots of coats. Arrived home this spring to find the joint leaking again. Or possibly even still.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have recently tried it, It appears to be working, but I used it to seal some electrical connections, Hopefully it will be several years before I find out how well it works.
  • The stuff "seen on TV" is usually something which has been around forever with a new spin on marketing. That "new" spray sealant is the same stuff you've been able to buy for evaporative coolers for years. Its just a rubberized aerosol spray. I'm sure it works just fine, depending on what you want it to do. I just wouldn't buy the 500 cans you'd need to seal your screen door on the bottom of your boat. Buy a better boat.
  • I just saw a add for Rural King and they have it.
    No personal experience but I saw it on Television so it's got to be true.
    Want to buy a bridge?
  • It's in local stores...I've seen it at Home Depot, Walmart and even Walgrens Pharmacy and grocery stores in the "As Seen On TV" section.
    I've never used it but do have a couple of projects where I plan on trying it.
  • I used it on a garden fountain that was leaking and two years later it still holds water. I have seen it for sale at Bed Bath and Beyond,Walgreens and I think Lowes.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
