wa8yxm
Jul 17, 2017Explorer III
What chassis is it?
Workhorse for example Fan is under dash, passanger side, about 4 or 6 screws to remove blower and motor assembly and 2 wires.. No special tools needed or skills, just a screwdriver. Easy to do if you if you fit in the area needed.
On some others.. The engine side of the fire wall.. Same assembly .. I mean Same part number in some cases same assembly so the procedure is the same,, Fit may be tighter though.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
