mobeewan
Jun 09, 2018Explorer
You might try making some wire covers to fit inside the shroud where the Shroud openings are. You'll need to use wire cloth with the largest openings you can that the squirrel won't be able to squeeze through. You can compensate by loss of airflow by making the covers in the shape of a rectangular pan like the bug covers they make for the furnace Inlet and Outlet and the water heaters.
You'll need to add the screen at the bottom edges of the Shroud to keep the squirrels from crawling under the shroud or you might use some PVC pipe and elbows to make a frame that you can place around the bottom of the air conditioner shroud to keep the squirrels from crawling under the shroud. The pipe will need to be removed when you run the air conditioner.
Hardware cloth
Hardware cloth
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
