CA_Traveler
Jan 28, 2022Explorer III
Have the battery load tested to be sure it's OK. With a discharged battery a 3 stage charger will ramp up the voltage to 14.6V - bulk mode, hold 14.6V until about 85% charged - absorb mode, then taper the amps and voltage and amps to 13.6V - float mode.
Float mode can take many hours to reach 100% because the amp charging rate is very low.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
