CA_Traveler
Jan 28, 2022Explorer III
Also check the calibration on your voltmeter and the above is for flooded batteries.
Other RV loads can change/reduce the battery voltage and amps while charging. Once float voltage 13.6V is obtained it should remain there unless the RV draw exceeds the charger capability.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
