DrewE
Nov 02, 2015Explorer III
The heated mirror switch is pretty common. Leaving it on will run down your chassis battery before too long (if the engine is not running), assuming it's wired hot as is not uncommonly done.
The switch above the sink may be for the water pump or the water heater. It also might be for a bunch of other things.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
