j-d
May 07, 2015Explorer II
Post Model Number and Spec Code. Somebody here can find you a Shop Manual with Wiring Diagram. I bought a used ONAN and needed the connector from coach wiring to generator's remote control connector. Local Cummins/ONAN distributor had it in stock, and that was for an older generator.
You can't post photos directly to this Forum. They need to be on a photo site, your personal webpage, or even most advertisements will post.
Once the photo's up, enter Advanced Post Form right by the Quick Reply box here. Then the yellow "post card" Paste the photo's web "Properties" into the dialog box, max width 480, and it should be visible here.
When you EDIT a post you've already made, you're put into Advanced Post Form automatically.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
