Look at your shore power connector. 30 amp shore power look at the round pin. wiggle it. moves too much easily the wire has broken off. Check in your 120 volt power distribution panel for loose connections. dis connect from shore power, then remove metal dead front to gain access.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
