BartonT's avatar
BartonT
Sticky hydraulic levelers
The levelers on my class A work well except when it time to pack up and leave. Often 1 or 2 will stay down. I now carry a 6 foot 2x4 and a wood block to push them back into the stored (up) position. Each leveler has two springs attached to the ground pad and the springs seam to be applying enough force that they should pull the Pistons to the up position. In owners manual says very clearly not to lubricate them in any way but after 11 years it does not seem unreasonable to expect something to have dried out a bit. I have tried moving them up and down to try and free them up but this has not been enough. Is there some thing I can use to provide more lubrication? Any other suggestions?
