BobDye's avatar
BobDye
Storage of water filter
My water filter won't be used for several months. What suggestions do you have for storage?
  • Our water filtering has evolved, including the aforementioned Camco blue cheapy. Currently we are using a Dalton ceramic pre-filter which can be cleaned and reused which filters down to .5 microns and a carbon block which removes most chemicals down to the 99.99% level.
    And yes drain, but if the filter incorporates silver which helps protect the filter from growing.
  • Drain it, dry it out, stow it anywhere convenient.
    You may have a much beefier one than I use, but this is about the only way to do it. Granted I use a Cameo in-line (blue Wallmart cheap-o), but all I do is drain, and let dry. Drying is the important thing.
    If your is more advanced, take it all apart (the best you can), remove the filter and let everything dry completely. If you store it wet, you'll have mold or something growing in it eventually.
Having RV issues? Connect with others who have been in your shoes.24,305 PostsLatest Activity: Aug 27, 2025
