mikestock's avatar
mikestock
Storage RV lot with GFIC breakers
I have had my rv's stored in this lot for 17 years with an electrical hookup. The last 10 have been a 40ft. Tiffin Pheaton. Ever since the Phaeton has been here we have had problems keeping the 120 volt 15 watt GFCI breaker from opening. I am not the only one in the lot that has the same issue. Usually, the only thing operating is my charger to maintain the battery banks although all my ac receptacles are available. I have a household fridge which I like to keep plugged in if we're planning a short time between trips but I am concerned it will be shut down. I have checked the power draw which is under 120 watts even with the fridge on. I keep the ice maker turned off to keep the ice heater from overdrawing power.
If I don't keep a regular check I will find the breaker out. One of my neighbors has the same problem so he keeps a check for me also. We're not the only two on the lot with the problem. The owner is aware of the issue and also has problems with other units.
I am looking for any idea as to what/if anything I can do.
Yes, I meant "amp" not volt-amp.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
