Community Alumni
Jun 14, 2020Not applicable
I have Nev-r-lube bearings on my 5th wheel. It is 16 years old and I replaced the bearings at 10 years. They felt okay but the seals were leaking a little. The new bearings were pricy- over $100 each and I had to have a machine shop press the bearings out & in. I check for end play and noise each spring and about every third year I pull the hub and examine the brakes. I reuse the lock nut which has to be torqued to specs. Personally I like them, less messing around with grease, IMO.
