myredracer
May 14, 2019Explorer II
Harvard wrote:Not sure I understand the logic on this? In a 120/240 volt panel you get cancellation of the magnetic fields, whether the neutral is unbalanced or not. In a 120 volt service, the hot and neutral carry the same amount of current and the magnetic fields cancel out also. Doesn't matter if it's a supply to a panel or a branch circuit. Or maybe you weren't clear in what you were trying to explain?
This would not be the case in a 30A RV because all the Hot Wires are going in the same phase at any given time.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
