Harvard
May 14, 2019Explorer
Harvard wrote:myredracer wrote:Harvard wrote:Not sure I understand the logic on this? In a 120/240 volt panel you get cancellation of the magnetic fields, whether the neutral is unbalanced or not. In a 120 volt service, the hot and neutral carry the same amount of current and the magnetic fields cancel out also. Doesn't matter if it's a supply to a panel or a branch circuit. Or maybe you weren't clear in what you were trying to explain?
This would not be the case in a 30A RV because all the Hot Wires are going in the same phase at any given time.
Not 100% sure but I believe the answer has to do with the difference between Electric Fields and Magnetic Fields.
I think the physics of capacitance is related to Electric Fields.
Think of it in terms of when there is a HOT and NEUTRAL with no current flowing (to a load) OTHER then the leakage current.
The Electric Field would dominate the Magnetic Field.
It is time for the Electrical Engineers to chime in....
To explain further:
When you have split phases the voltages to N/G cancel out...
When you have a single phase the voltage to N/G is not cancelled.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
