ksg5000
Nov 29, 2016Explorer II
Start with the obvious/easy stuff. Starter relay and loose/corroded ground would be high on my list. Had a car which had similar problems and dealer couldn't find the problem - neighbor mechanic discovered loose wire in ignition system. Go figure.
