TheLostBoy
Jun 28, 2017Explorer
beemerphile1 wrote:
Follow the line back to the nearest threaded fitting and repipe from there. In case you are not aware, do not use any compression fittings for LPG, only threaded or flared.
It goes back to a "T" valve, but I don't think I'd be able to make that fitting work with standard 3/8" copper tubing. It's some sort of old European fitting (similar to the photo I took above of where the heater used to be). It looks like a compression fitting though, and I may be forced to use that as this tubing cannot be flared (tried and I think I almost broke the flaring tool). Very thick stuff.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
