joe0508's avatar
joe0508
stripped nut
I have a battery post that i cant loosen or tighten.It is loose and i cant tighten it down.Does anyone have any suggestions on what i need to do to get the bolt off?
  • If the thing is loose turn it back and forth while getting screw driver under terminal to force up and off then just cut bolt
  • Can you put another nut on it and extend the post?
    Otherwise a nut splitter is the tool you need.
  • Ron3rd wrote:
    I would cut if off with a small cutoff wheel like a dremel and start over.
    that is best way, or try hacksaw on middle of bolt where it is weak
  • Ron3rd's avatar
    Ron3rd
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,247 PostsLatest Activity: May 14, 2025
