msmith1_wa
Jul 17, 2016Explorer
I doubt you have one but if you have a vacuum power brake booster it could be bad and causing a large vacuum leak. You probably have a hydraulic booster though.
Based on the symptoms the next logical thing seems to be the transmission related. The Allison transmission uses a separate computer from the engine, so it is likely your scan gauge won't read the transmission codes.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
